spotlight active while sculpting ? (answered)
I am wondering if it is possible to keep spotlight active while sculpting.
At the moment if I have it set up like this
[ATT=]referencevisible.jpg[/ATT]
I can continue to use the Move Brushes but no other brush works.
Is there a workaround for this ? I really like spotlight as a quick reference base
Turn up the radius of the Spotlight until it’s huge. Then when you hit z to go into paint/sculpt mode, the spotlight radius will be so big that it still shows the textures.
In the Brush>Samples menu turn off Spotlight Projection. You will then be able to sculpt with all the brushes, and have the images visible.
thanks that helps so much!
