hi,
is there maybe a way to use zbrush on two screens. I would like to have my canvas only on one screen and mij tool palletes on the other. is there a way to do this?
Marcel
hi,
Marcel
It technical can be done, but it’s complicated.
First, both monitors must have the same resolution. You can then click the resize button in the title bar, then use the lower right corner of the interface to drag the desired edge across onto the second monitor.
Build out your interface however you would like using the various interface customization options.
When satisfied, press Ctrl+Shift+I to save the new configuration.
What most people do in your situation is to put the canvas on one monitor and have one open tray on the second. Also on the second they put everything from the top and opposite side shelves. The side shelf can expand quite a ways, so you’ll be surprised by how much you can stick on that second display.
thanks again for the information Aurick
