split hidden different subdiv issue
yo!
i split the head part (via split hidden) from the rest of my mesh to add one more subdivision, and now i got these weird breaks at the borders.
is there some simple solution to this or do i have to readjust this manually?
thanks in advance!
Rizz
you have to turn off the smoothing in Tool:Geometry:Smt (right next to the Divide button) before you subdivide.
(ds)
ah well, thank you.
but is there any chance of welding the gaps afterwards? :o
You can use Tool:Subtool:MergeVisible with the Weld button pressed.
If you still have small gaps you can export the merged mesh as an OBJ and then use Tool:Import:ImportTool with Mrg turned on and play with the Weld setting.
If that doesn’t work then all I can suggest is welding the points in another software.
Ukai, i’ll have a look.
Thanks so far.
