I’ve used Zbrush since version 2.0 and I’ve never had a solid solution for bending/twisting an object.
Imagine you have a straight fang that you need to bend inward…whats the easiest way to do that?
In Modo they have a spin Brush that makes this type of thing a breeze.
Is there some kind of ZB equivalent or maybe some fancy trick to achieve the same effect?
Thanks.
