Spheres can't stick to the mesh
HI,
The problem is that sometimes when i re make my typology on the model with Z-sphere. IT will not stick to the mesh,I turn off/On the edit topology button but nothing happen. so it becomes diffucault to retopypolize my model because I can’t see the lines straight.
But the Projection works…:confused:
I’ve never encountered anything like this. Have you manually moved some of the points away from the mesh? If so, that would be causing your issues because if you try to add points to an area where you’ve already got retopology going on, ZBrush will give preference to the new topology rather than the source mesh. This means that ZBrush will attempt to snap to the structure that you’ve moved away from the source.
For this reason, I prefer to wait until I’ve completely covered an area before I move any of the points around.
