Sorry, only one Zbrush instance may be launched from the same directory. click to exi
Need help asap with my zbrush i keep getting this error message my zbrush was working fine earlier morning i dont what the heck happened not it wont open
Sorry, only one Zbrush instance may be launched from the same directory. click to exit
also tried one of the threads here that had the same issue…didnt work…how to check what “phantom” processes are still running?
You wouldn’t be running dual monitors and have one shut off by any chance?
What OS are you running?
Nope dual monitor is turned off
Should show in Task Manager if it’s running and from there you can kill it. I think I read about holding Alt on launch for some reason but not what it was(maybe program hang at launch)?
>_<
i already tried and cleaning the registry, install and reinstall,“last best configuration” restart thing but still doesnt work >_< i need to get this fixed asap ><
“What OS are you running?”
windows 7 ultimate
You should submit a Pixologic Support ticket.
