yes that mean more maps for one object for better quality…
hmmm…
what resolution du you use? 4000x4000???
thx
elron
hmmm…
thx
elron
yes 4000x4000
Oh wow, that big? Really?
Check your mail mate.
ciao.
wow I love all your models dude. keep working hard man you are the best.
I really need some help in one thing. how can you drag a 3D max 7 model to Zbrush?
narutochen : thanks man, the way to do it, is once u have ur model done in max, file-> export and use the obj format, then in zbrush, tools, import, and u will have the file in zbrush, is quite straight forward!
Great model, I haven’t used zbrush yet but, I am going to get hip to this! Nice stuff man, I hope I can get some help from you in the near future…holla!
Phenomenal models Alex! Do you have a website or any tutorials a DeviantArt account? Where can we see more of your stuff man?
wow i thought this thread was already dead!
imhotep thanks for the comments, i’m glad that u liked them! u can visit my webpage at www.metamesh3d.com…
… can you import those models in max ?
¿Cómo empiezas el modelado? ¿Partes de un modelo base? ¿Importas la figura o la haces en ZB?
popoff yes u can import/export between max and zbrush without problems.
saltapiedras, hice los modelos basicos en 3dsmax y luego todo el modelado en zbrush, podria usar zspheres pero voy mas rapido en max, lo tengo mas por la mano!
Hi MetaMesh…great stuff…AMAZING STUFF!!
You mentioned you use VRAY for displacements…are you able to get similar results using the standard Max render…I have very poor results using displacements within Max. Wondering if you could share some enlightenment on this. Is VRAY the way to go?..or can you achieve decent results thru Standard Max?
Hi Clubitz, i´d say that Vray is much better for the displacement…the quality is the same that u get in zbrush, is just great…if i have to use the standar max scanline, what i use to do is to add a meshsmooth modifier to the object, set the modifier to let´s say 3 iterations ( even 4) in the render time, and set a displace modifier over the meshsmooth…u can get pretty nice results in this way! but if u put too much iterations, max will just crash…so jut try with that, otherwise vray is the way
… i cannot export/import my models in max properly
, they are on facetes … may be i make some mistakes …
popoff once you import your model to 3dmax and you have some facetes, try to add a smooth modifier ( not meshsmoot, not turbosmooth…just a “smooth” modifier, and then set it to auto smooth with an angle of 180…you should have you model smoother out then…try it and let me know if it works
Ehi Metamesh!!!I was thinking that I had already posted this thread but it seems I’m wrong…Anyway that’s a work that reflects your style…a MASTERPIECE as ever…
Hope to see new updates soon…
WANNA LOOK?
ALIEN FACE HUGGER
FANTASEA…WIP
MattHHH
hi man long time no see what di you mean about the 3d max? I am going to try to convert my model to odj tomorrow and try it out in Zbrush~
its realy very cool work…
hey can you tell me how to make texture of real skin… thanks.
deepthanx … Ill try smooth modifier later today ... and Ill inform you what I have done
hola Alex.
Dejame decirte que estoy super impresionado con tus modelos, son extraordinarios en todo el sentido de la palabra.
Me ayudas con algunas preguntas, please…
-Que sistema de modelado usas?..box modeling, poly by poly…?
-Que tanto de la forma trabajas en 3D max y que tanto trabajas en Zbrush?..es decir, algunos artistas trabajan la forma hasta casi terminarla y luego añaden detalle en zbrush…otros trabajan la forma de manera muy muy basica en max o maya y luego trabajan todo el resto en zbrush…como lo haces tu?
-Tus renders son fantasticos, que tipos de luces usaste, cuantas, etc?.. y cuanto tiempo aproximadamente tardo el proceso de render?
gracias…y por favor comparte mas de tus fantasticas esculturas con nosotros.
Saludos
Yolao
