Some questions...
Hi guys. Recently i’ve installed r6 version and have some questions.
  1. I’m using CurveStrapSnap brush. I can’t change diameter of stroke.
    I’ve tried changing diameter and focal, when my cursor over the line and had got blueish color, but
    no effect. I picked my line again to see changes - but nothing happened… Are there any tricks using
    this type of brushes ?
2)How to FreezeSubD Lvls without projecting all details of highest lvls? I mean i created some polygroups
with FreezeSubd lvls onn and change geometry a bit, but after turn off Freezing, my new lowpoly projecting
into the previous Hipoly. I don’t want to project entire model.
–many thx for answers…
About the diameter. Be sure you have your brush cursor in red color as a normal brush. This size (While red cursor) determines the IMM size. The blue cursor it´s for editing the curve after. So it has independant size for this purpose and will not change your IMM mesh size. Just need to go away from your inserted mesh and while your cursor in red modiffy your brush size. Then click again on your curve and you will have your curve updated.
About avoiding projection after freezeSubdiv it´s something i want to know too :slight_smile:
