Some probles with views in Zapplink
Hi everyone. I met this kind of trouble just on my model,when i create new or,for example,use demohead all is ok).So,when i click right or left view Zapplink genarates me the same picture.It doesn`t change the view.The same trouble with top & botm :eek:
Try the following:
In the ZAppLink Properties menu, press the Clear To button, followed by Top. Then repeat with Bottom. Now on the canvas, rotate the model so that you have the desired top view. In ZAppLink Properties, turn on the Top button, which will also turn on Bottom. Now clear the Left and Right options. Rotate the model on the canvas to what you want for the Right view. Then turn on the Right option, which will turn on Left.
Creating the character sheet should now give you what you want.
Thanks aurick. Your advice was very useful to me. :wink:
