I have a few questions regarding some tiny annoyances that I hope I can solve out here.
Whenever I click on the transpose tool circles to move or whatever there’s some snapping that suddenly moves/scales/rotates my model abruptly so I can’t make small adjustments, is there a way to work in small increments?
I made a custom drop down menu, the problem is all the submenus are extended, is there a way to default them to shrinked/folded?
Also I would like to change the order of some submenus within this custom menu, when ctrl+alt+click it edits the submenu title so I can’t seem to move it around to another place.
Since the popup Quick Menu (spacebar) can’t be disabled, is there a way to edit it? so I can leave only the few items I use mostly.
Zbrush seems to be set as “always on top”, it restores when minimized when I open other windows, thus sometimes misclicking on error. Is there a way to disable this behavior?
Thanks for the help!
