Some buttons off UI on smaller display (solved)
Is it normal to have the “Activate Edit Opacity” on the right shelf of the interface to be barely visible? I can still click the button by barely touching the top border.
On smaller displays some buttons in the standard UI are off the screen. (They are still available in the Transform palette but obviously that’s not as convenient.)
This configuration will solve the issue:
  1. Unzip the file to your ZBrush 4.0\ZStartup folder.
  2. Start ZBrush and press Preferences>Congig>Load UI. Select the SmallerUI.cfg file from the ZBrush 4.0\ZStartup folder.
The adjusted UI will be loaded. The buttons that you were missing have been moved to the top right of the UI. You may need to close the right tray (with the Tool palette in it) in order for them to appear - to do this click on the divider.
If you are happy with the new layout save it as your custom interface by pressing Shift+Ctrl+i.
Thanx for your speedy response!
