Sorry for resurrecting an old topic, but after spending a few hours reading old topic for creating a zscript for remeshing in batch lot of objects I’m a bit confused (almost 3000)
Before starting to describe why I’m confused, I need to say that I need a batch since even if I can merge all sub autogroups and then again split my obj I would lose the names of the subobjects which for me is vital (all the obj comes from anatomy scans and so the name gives a precise anatomical classification+scientific name of the scanned body part)
I’ve created a script that open an obj, zremesh the obj and then save it. I’ve undeserstand that I should probably use ZFileUtils DLL for 4R7 but I don’t know if it will work on Zbrush R8. Also I find the syntax a bit confusing.
So is it possible to open the obj in batch, run the script and then resave with same name (or adding just a letter to the name) ?
If anyone has tried in zbrush r8 please let me know.
Thanks in advance for the reply.
Giorgio
edit-
The script included worked like a breeze. It made me spare days ! Thanks !!!
