(SOLVED) Transpose Tool Roll Function Not Working (Rotate)
I used to use the transpose tool to roll my forearms on my arm. I would mask my body down to the forearm, then draw action line down the center of my arm, then make sure I am on rotate for the transpose tool and then use the middle circle on the transpose tool to roll instead of rotating. This isn’t working for me anymore. Did this change? Am I doing this wrong? Or is this a bug?
Thanks, NickZ. :slight_smile:
It’s working for me Nick. Center circle of Rotate Transform will spin around the axis of the Action line. I’m on PC though. Are you on Mac by any chance?
I’m on PC. I have had lot of trouble getting this to work. It rotates but it acts like the rotation line is way off in space somewhere??? Not sure what is going on with it.
Try turning on “local symmetry”.
That did it!!! Turning on Local Sym and now it works!!! Woot Woot!! Thanks everyone.
Bad post. Sorry about this. I was meaning to post in a different area.
