"SOLVED" - Spotlight Sculpting - "Spotlight Projection Stuck?"
Greetings,
It would seem as though spotlight is stuck in image plane mode, when "z" key is pressed to remove the spotlight dial the mesh can be sculpted as normal.
I have checked to ensure Spotlight Projection is turned On; “on” or “off” makes no difference.
Thanks for your help!
“Found the Issue”
Spotlight Radius in the dial was turned all the way down.
