[solved] exported .obj with null vertices values
I have created a model in ZB3.2, it’s displaying correctly, no problem of any sort with it. I export it to .obj (I want to use that in Poser) and the exported .obj shows all “na” in place of vertices coordinates.
Is this happened to somebody before ? Any way to get my model exported ? I’m going to cry like a baby if there is no way to do it :grimacing:small_orange_diamond:grimacing:small_orange_diamond:grimacing:
To add more informations, I tried to export the model using the Subtool Master Plugin. Here is the error it tells:
“SKIPPED importOffsetXYZ since bad scale implies no mesh3D”
Well, I solved it: went to the export panel, and noticed that Scale, XYZ offsets were all set to “Nan”. After restoring those, I was able to successfully export the .obj.
Hope this might help someone else …
I got the same error message using Transposee Master and i solved my problem thanks to this thread!
Many thanks!
THANK YOU!!! I have been pulling my hair out all day with the same problem. Resetting the scale to 1 from NAN in the export sub menu fixed it all!
