Snap planer brush to Y axis
Snap planer brush to Y axis? I want to make some parts of a map totally flat. Thanks in advance peoples.
Select your brush then under stroke, activate lazymouse, backtrack, snaptotrack and line. When you start your stroke press shift and the stroke will constrain to whatever axis you started the stroke with. With backtrack activated, keep in mind that the actual stroke will begin when you start the cursor back toward the start point. All of this applies to any brush. Hope it helps.
What If I dont have a flat surface to start from?
