Snap geometry to grid?
Please help! I am building a scene with a lot of buildings some are dynameshed and I would like to have them all on the grid, I tried doing it by eye but with no luck there is always an offset of a few mm’s. Does anyone know how to do it? It would help me immensely. Thank you for your time and help.
There is no snapping as you would like, but you can goZ them to an application that does allow snapping.
Alternatively you transpose master the mesh, then slice the bottom of all of the meshes at once.
You could also use the remeshing options with the same cube duplicated over and over again to be used as a subtraction boolean mesh.
