snake hook brush
Actually i want to use dis brush to make hair of my character. but when i try to pull out the mesh. it does not come out good. can u pls tell me the way to use snake hook brush.
You probably won’t get good results for hair. The brush can’t create polygons. All it does is pull them around. This stretches them out the farther you pull them. So the longer the hair you’re trying to make, the worse the brush will do.
For long hair you might use other techniques such as using ZSpheres to create locks of hair that you can then sculpt to look like they’re made of multiple strands. You can append the model to your head and then pose the ZSpheres to get the look you’re going for. By adding multiple locks, you’ll quickly build up a hair style.
There are other techniques, too, such as masking and extracting to create a skullcap that you then sculpt.
thanx aurick.
Hay,
Mi name is Bogdan Petry end i ame from Roamania. ZBrush is grate. Is genial.
From myself I try to make a comic ilustration. I made almost in Zbrush 3 in one moon, bat i use also Cinema 4D. Carrara 6 end Photoshop.
Anyway, I send to you my work end i hope you like.
In my cantry I ame caricaturist. In 2000, I work one year to The Oregonian daily paper end for me was a grate experience.
My blog is : www.artofpetry.blogspot.com.
I finish my letter en sory for my English.
With great respect, Bogdan Petry
