SmoothUV + 3ds Max
I’m rendering with Mental Ray in Max 2009. I always subdivide my models when I render them with displacement maps. I usually use TurboSmooth to subdivide in Max.
My UVs are being created on the level 1 base mesh in Headus UVLayout, and they look good when they’re not subdivided.
What is the correlation between the SUV button in Tool: Geometry and the SmoothUV button in Tool: Displacement? Given how I’m creating my UVs and rendering my models, should I be using these two ZBrush features?
I looked around for an answer…
The Online docs have this to say:
Sym, Mrg, IExtr, ReFit, Suv, I-Grpm O-Grp: See online documentation.
I see. Onward. Scott Spencer’s ZBrush to 3ds Max guide has this to say on the matter:
Tool:Geometry:SmoothUV will also affect the final result.
More from the online docs!
Smooth UV: Affects the “smoothness” of the final effect when the displacement map is applied. When sculpting organic models, you will normally want this on. If your model has sharp edges and you find that they are not maintained adequately in your renders, you may want to try making displacement maps with this turned off.
Ah-ha! but I have heard that this depends on your renderer and certain other factors. I honestly am not certain if Max is subdividing my UVs or not. I don’t know if TurboSmooth smooths UVs as well as geometry. I also don’t know if there is some render time UV smoothing occurring.
I found a similar thread on a Mudbox forum, but it seems to be as nebulous a subject for them as it is for us.
MUDBOX THREAD
It turns out Max does subdivide UVs when you subdivide the mesh, but it only subdivides the internal UVs, including internal UV seams. The outer seams of each UV shell remain linear. Neil Blevins has an article on his site that discusses this problem.
Here’s my base mesh.
[[attach=155715]basemesh.jpg[/attach]]basemesh.jpg
Here are the UVs I made for the base mesh in Headus.
[[attach=155716]uv_headus.jpg[/attach]]uv_headus.jpg
I did not use SUV when subdividing in ZBrush, and I did not use SmoothUV when exporting my displacement maps in ZBrush, so I assume ZBrush made no changes to my UVs. It’s difficult to tell for sure since I haven’t found a way to see the wireframe of UVs in ZBrush.
[[attach=155717]uv_zbrush.jpg[/attach]]uv_zbrush.jpg
Here are the UVs back in Max after applying TurboSmooth. Exterior edges are linear, internal edges and borders are smoothed.
[[attach=155718]uv_max.jpg[/attach]]uv_max.jpg
The question remains. Should I use SUV or SmoothUV in ZBrush? I’m not entirely clear on what these features do, despite reading the Online Docs and searching these forums. How do I determine whether or not I should use these features?
