smoothing groups & zbrush?
Does zbrush support smoothing groups? how do I import & export them between zbrush and 3ds max? Every time I import a model with smoothing groups into zbrush they all vanish and the model is without smoothing groups (every poly is visible).
from the lack of responses I gather Zbrush does not support them huh? perhaps I should elaborate. Any way I can at least set them up in zbrush from scratch if import/export isn’t supported?
Smoothing groups are a Max feature, and not part of the OBJ format. Have you tried using ZBC’s advanced search feature for “smoothing groups”? You’d get about 3 pages of results, some of which are specific to Max.
thanks mate I’ll search :slight_smile:
man im having the very same trouble, i did a search with no success, if u find some good answer on this pleeeasee, please post it here … it will be really apreciated…, ill keep researching this problem and if i find something useful ill post it here as well. :slight_smile:
As long as you export only smoothing groups in your OBJ you could do this:
  1. Export the OBJ from Max.
  2. Open in a text editor that can handle large files and do a search and replace, replacing the ‘s’ tags with ‘g’. This changes them to regular groups.
  3. Import the edited OBJ into ZBrush. Your smoothing groups should appear as regular polygroups.
  4. Ctrl+Shift+Click to show a single group and press Tool: Geometry: Crease.
  5. Repeat (4) for the other groups.
