Smooth brush at hi-resolution
hi all!
i was wondering how can i smooth a line traced on a subtool at hi resolution and at hi-subdivision level.
the standard smooth brush and the “stronger smooth” brush are not enough also using the “smooth brush modifiers” in the brush palette…
i would like to smooth a line at hi resolution in the same way i do at lower resolution…
The smooth brush doesn’t work the way you’re thinking.
It averages the verts that are effected by it.
If smoothing isn’t working anymore it is because the verts are already averaged.
You’ll need to step down to a lower subD level so the averaging happens across a larger “area”
You can also “smooth” out the area by hand using deforming brushes like standard, clay, etc.
thank you for your answer!:wink:
i usually do what you said, but when i smooth at lower sub div level when i return to the higher sub div level remains some artifacts that are hard to be removed.:mad:
thanks anyway:)
