Smooth Brush and Object Edges
Whenever I use the Smooth Brush on an object with an open edge the smoothing only affects the verts on the inside and not the ones along the open edge. This was not the case in previous versions of ZBrush. I used to be able to smooth away poorly projected areas but now I can’t. Can someone please tell me if this is some kind of option that needs to be turned on now?
