Smooth and Move brush not working in scene
Is there any particular reason the smooth and move brush would stop working in a particular in a zbrush session? All the models are in separate subtools. It’s as if these two brushes have been disabled. I also tried resetting all the brushes but that did not change anything. It’s definitely related to this scene.
I’m able to use most of the other brushes but these two.
When I load any of the stock tools it works fine.
Thanks, F
Here are some possibilities.
  • make sure you don’t have any masks applied. go to the mask menu and hit clear all masks.
  • make sure the intensity for your brushes is set to something higher than 50. also make sure the brush mod is set to something higher than 10.
Hello,
Thanks for the input!
I just figured out what the problem is. It appears to be a scale issue. Somehow going back and forth to Maya, the scene got scaled up.
So the move and smooth brush will not work if your models are scaled to big! :eek:
Thanks again,
F
