using a 17 inch standard art monitor.
1024X768
…working screen is comparatively smaller than my 3.1 version. :(…
when i zoom things get pixilated…
anyway to fix the resolution?
1024X768
First, you probably want to create a StartupDocument that is twice the default size. (See the online documentation in my signature for how to do this.) That will let you work with a canvas that makes the most possible use of your screen.
Second, you can reduce the size of the interface elements. In Preferences>Interface you can reduce the Button Size slider value. You might also want to try turning off Wide Buttons, depending on your tastes.
As for pixelation when you zoom, are you confusing canvas Zoom with model Scale? Zooming the canvas will always pixelate whatever is on the canvas, just like zooming into a picture in Photoshop would pixelate that.
thnakyou it worked
but when ever i initialize or start with new document it again shrinks down?
is there anyway to make the modified size as a default ? so even if i initialize it remains the doubled version?
As mentioned in my previous post, please see the Online Documentation linked to in my signature. That tells you how to set up your StartupDocument.
