I’m customizing my interface and I can’t find a way to get the small color picker I see in other interfaces. The one I can drag from the Color menu is huge, and I can’t figure out a way to move the color picker from one interface to another. I’d like to not lose the changes I did so far to my custom interface, is there no other way other than start from a interface where it’s already small?
Thank you in advance for your advice!
There is a small color picker in “Color > Modifiers” submenu. You can drag it from there.
Just as reminder. Letter “C” is the shortcut for color pick
Thank you very much!!! That’s exactly what i was searching for, I feel ashamed I didn’t spot it, i was searching in all other menus for it other than lower down the color menu. Thank you!
No problem!
Don’t neglect using the quick menu which can be accessed by right click(if enabled) or the spacebar. On right click it stays open until you’ve made a selection or move off the dialog box. This will allow access to about everything and disappear after use leaving you with the most possible space(Afaik). HTH
Would be great if that quick space menu could be edited, especially to show the subtools or another such premade section in the tool menu.
