Hello,
I searched for a while to find a function where I can switch to fine adjusting the UI slider.
I can’t believe that there is no option like i.e. LMB = big steps, LMB+STRG = small steps.
So I am sorry if I just over viewed it.
This would be very comfortable for adjusting Deformers, BPR Filters…where ever fine steps causing big changes.
Thanks for your help.
EDIT:
This is what the doc is saying, but not what I am looking for. Maybe there is really no function for fine adjusting sliders with mouse?:
“Sliders: These allow you to set numerical values within a given range. For example, the Rgb Intensity slider allows values from 0 to 100. To change the value, click and drag on the slider. For a precise value, you can click once on the slider, type the desired value, then press Enter to set the value and deselect the slider.”
:lol:
