Slice Curve Brush doesn't cut properly with Dynamesh
Hi! Cutting an object in half with the Slice Curve brush in dynamesh mode creates extra polygroups between the cut which makes the two halves impossible to separate. I’m having this issue in ZBrush 4R6 P2 whenever I dynamesh an object with the Groups option turned on. I know this is not how SliceCurve should work, but I can’t figure out why is this happening. I’m still running ZBrush 4R4 on my computer and this tool works perfectly fine there! Don’t understand! Hope someone can help!
turn polypaint on then re-dynamesh.
Many thanks for the quick reply beta_channel! YES, this solves the problem!! (I just still don’t understand why this issue occur in the latest version of ZB.) Anyway, thanks for your help!
