Slice curve brush and symmetry?
I’m loving the new slice curve brush, but I can’t make the symmetry work with it. While it shows the mirrored white dots, it only works on the side you are actually working on. Is there a setting I haven’t turned on?
In the documentation it describes how the Slice Curve brush does not use standard symmetry. You can establish symmetry by using mirror and weld.
