Skinshade4 error message
When trying to make a clone of a subtool in UVMaster I get the following Error Message, I’ve looked over the FAQ and tryed to figure out what is going on but can’t seem to figure the reason for this error, hoping someone can help with this error message.
Zscript Note: interface item could not be found
Script : UVMaster_2018.txt
Error : Material : Skinshade4 in : [l press, “merterial : Skinshade4” ]
don’t how to correct this, does any know what’s going on here?
merterial ?? Is that how it is really spelled in the error message, or is that a misspelling by you?
Anyway, go to the installation directory “ZBrush 2018\ZData\Materials\Startup” folder and see if “SkinShade4.ZMT” is in there. If it’s not, then that is probably the problem. Did you delete or move that file? Is “SkinShade4” in the “Materials > Standard Materials” palette?
Zber2
Yes that is a type-o by me, It’s suppose to be Material :o
The skinshade4.ZMT is in Applications/ZBrush2018/ZData/Materials/Startup/SkinShade4.ZMT
It sounds like you are on a Mac. The only other thing that I can think of is that it might have something to do with access and permissions. I’m a PC user so I can’t help you much more than that. If you can’t get it going, log in to Support and Submit a Ticket.
