Hello,
I have a bit of a problem, and I can’t find solution anywhere on the web.
While poly painting, default size of the map is 1024x1024, and this is not enough, and it leaves texture pixelated. Ofcourse, I can convert that map to higher value, but it still stays pixelated, since it was 1024x1024 while i painted it.
Also, while I paint, if i zoom closer to the model, it is visible that i don’t have enough resolution.
Are alphas problem, or is there other way around this?
Many thanks in advance!:rolleyes:
