Single Axis Navigation
Is there a way to rotate your view around the model on a chosen axis instead of it tumbling? The 3 rotate options in the transform palette aren’t working for me very well. I’ve used timeline and keyframes to accomplish it so far.
Hi @travisbarker3d
You can use the Gizmo 3D.
@zber2 without physically moving the model?
Not by rotating it, no. There is a plugin that will set it to a selected view with one click. The Axis plugin by Roland Kaiser. I use it all the time. I can’t find a download link so I zipped it below. Just extract it to your plugins folder. Once you’ve installed it, you can find it at the bottom of the Tool palette in ZBrush.
Axis Tool Position 4R6 update.zip (3.4 KB)
edit: Anybody else seeing this that wants to download the plugin, it says 4R6, but it’s still working in ZBrush 2022.0.8.
2025-07-31 13_45_43-ZBrush
That’s a good plugin, I’ve used it a few time. I appreciate the help. I’m hoping that in the future they’ll adjust the navigation so that you can basically use the same actions that the Gizmo 3D allows for moving a model, but for navigation as well. For my CNC work I often to view my model from the side so that I can adjust it as I work, so being able to basically spin the view of the model without physically moving the model would definitely help.
@travisbarker3d
The squeaky wheel gets the oil. You can put in a feature request by submitting a ticket to Support.
Thanks I’ll definitely do so then.
