Simple texture question...
Ok…a really dumb question…I made a sculpt and saved it as a Ztool. I did some painting in ZProjection so I was prompted to save it with the Ztool, which I did. How do I apply the texture to my Sculpt when I reimport it?
You don’t re-import. You use Tool>Load. The texture was saved with the ZTL version of the model. That file format is brought back into ZBrush by using the Tool>Load button.
Right…I don’t have a problem loading the tool…it was that the texture was not showing on the tool. It had the default red clay material. I switched the material to fast shader and I can see my texture now…don’t know why. I’m still trying to get the hang of Zbrush. I’ll get there eventually…:smiley: Thanx Aurick.
