Simple question please help me!
Hey guys.
I have a small problem:
I created a mesh in Zbrush and then used 3ds max to create the UVW coords.
Now my question:
How do I import my UVW file into zbrush?? I really cant find the answer
Thank you in advance!!
Slice
  1. Export the file as OBJ from ZBrush to anything else
  2. Import OBJ into that other App, UV it
  3. Export the UVed mesh as another OBJ
  4. Import the new OBJ back into ZBrush at the same resolution that you 1st exported it
Make sure that nothing in your other app’s import/export settings – or anything else you do while the model is in the other app – changes the point count or point order of the model. Otherwise the model will explode when you return to higher subdivision levels in ZBrush.
Tnx for helping me out guys it helped me a lot:D
