shrinking when export Displacement
I was just wondering if anyone experienced shrinked Displacement Map when exporting them with UVSmooth ON ? I kept having shrinked Dis map around the edges but having UVSmooth OFF the result is very jaggies. How did you fix this problem ? Thank you
Before dropping to the lowest subdivision level to create your displacement map, try pressing Tool>Geometry>ReUV. See if that does the trick. You might try it with and without the Suv switch turned on.
Thanxs for replying. Still doesn’t help, the displacement map got shrink somewhere in the middle. I attached the picture so it’s clearer what i mean.
http://img166.imagevenue.com/img.php?image=185998508_uvjaggies2_122_477lo.jpg
