shortcut to show/hide model
When I model I try to match head position and shadows to reference images but each time I need to:
opacity=0; shader: flat
and then change
opacity=100; shader: standard
It would be very helpful to me if I could switch fast several times between only background and shaded model.
I have eyes, teeth… so I can not turn on/off subtools
Maybe you can use Image Plane plugin.
Well I think I do use it but I do not see optimos to swith between only image and only model
The only other way that I know of is to use the eye icon in the Subtool palette to turn visibility on and off, but I see you said that doesn’t work for you.
that also does not work. If I have one subtool then eye icon does not work, and if I have more subtool then I also have to make another one active and then I can turn ON/OFF the head subtool. But then I have to reselect it to continue sculpting so it is not very handy
