Shift Snaps and Scaling Acting Funny.
Sup guys, was wondering if there was a reason why sometimes shift(90 degree snaps) doesn’t work in ZBrush. Am I doing something silly? or does it just not work under certain conditions, or is it bugged? I’m using ZBrush 4R5.
Some of the actions I’m talking about is rotating, drawing in tools(in 2.5d mode), etc. Thanks.
Another question to piggy back off the other. Scaling is acting funny to me. I draw my action line and switch to scaling mode. No matter what direction i pull that scales down, after scaling down a tiny bit, it starts to scale back up. Any ideas?
edit: found the solution to the scaling issue elsewhere. someone suggested it might have to do with the size of my mesh. sizing it down under deformations helped with scaling issues.
Just bumping because there’s a few of us who’re still having trouble making shift(snap) work sometimes. I’ve noticed it’s mostly when I’m drawing a tool in 2.5 mode that snaps usually doesn’t work. Rotate and using the line stroke also don’t snap a majority of the time. I sometimes sit here hitting shift, click(to rotate), shift, click, over and over again until it finally does snap. I’ve checked my shift button, it’s working fine. Was wondering if anyone has found a fix, workaround or cause for this.
