Shift key opens tool window not smooth
I have been trying to follow the teaching videos but they seem to be different than my setup. If i press shift i get a item tool box window that pops up not the smoothing i see in the video. What have I done wrong? I have reset the inteface several times never get the smooth option on spacebar.
I am a bit confused. You should use the SHIFT key for the smooth brush and the Spacebar for the Quick Menu. Unless you have some program installed that changes the function of the SHIFT and Spacebar keys there is nothing wrong. Try again.
Somehow I was convinced smooth was spacebar it is indeed shift. Thank you!:o
No worries, I have had many a brain fart in my time. :smiley:
