Algerian tee service, made by Maya Zbrush and rendered in Modo 501
Very Good!!!
Congrats!!!
I like it, but I think it could be even better, particularly from Modo.
If you look at your settings on the render tab on the right in Modo, you’ll probably notice that you have Ambient Intensity on, probably set to 1 or 2. It is set that way by default. If you turn it off, everything will become much more realistic. AI is lame, these things don’t have luminous properties, after all.
Also, have more of the illumination coming from the Global Illumination and less from lights, that also adds to realism.
Also, turn bounces to 2. (Never higher, or you’ll be rendering for a week).
Pretty good so far! I hope to see a re-render.
I like materials. Good still life render.
Thanks Astrozombbie
Thanks 15051975
Thanks for comments EricShawn , i will do it to see the difference
oh my is that a… triple… triple rainbow dude!!! you use the SIBL in modo for lighting or did u set it up my hand?
i only used the kitchen environement
Brilliant work buddy.
Looks fantastic. I’m really diggin the design on the glasses and the way it rendered out. Have you thought about rendering it out with caustics?
Thanks!
يعطيك الصحة
lovely shay
Thanks man
Update…
just curious, as to why would you render this in modo when you already have it in maya?
in modo is fast & easy to render it
very nice render, especially the brass material.
looking awesome …
thanks
Thank you sanketpro3d
