Sharpening/strengthening detail on surface?
Hi, I just 3D scan a big sculpture (a man wearing armor) and scale down to
a smaller figure, and I prepare to use ZBrush to modified this 3D file then
3D print out it using my 3D printer.
The problem is, the rich details in the bigger sculpture must be strengthen
or magnify when doing down scaling. (e.g. the gaps between armor pieces)
So, is there any easy and quick way in ZB to accomplish this need? Just like
raising the contrast of a picture in the photoshop? If not I will need to spend
much time using brushes in ZB to sculpt them.
Thanks for help.
Acon
There isn’t an automatic way to do what you want that I can think of.
Something you can try is a mask by cavity, then invert the mask and do a negative inflate on those areas…worth a try.
