Sharing masks between layers
As I understand, masks now linked to some active layers, as well as polypaint, right? So, is there any tips about sharing masks between layers in zb4? For example, I have created some mask in layer3, but I want to use it in the layer1 and layer2 also (as starting point for creating more complex mask for example). When I leave layer3, mask disappears. What to do?
Make a stencil from the mask, then use the stencil on the other layers.
Thanks for answer, but stencils are good only for a flat parts of the mesh. What about curved masks, for example, pattern around sleeve? (I know about old “good” create alpha->mask by alpha method, but maybe there is something else)
For complex mask like that why not just use the create alpha, mask by alpha method, it works fine across layers, I just tried it.
