Setting Up Zbrush 4 Folders on an External HD.
When I setup Zbrush 4 I set it up on my internal HD and as these folders are getting bigger I would like to move them to an external HD. Is there a way to do this so ZBrush 4 knows where the new files and folders are by default. And which files and folders should not be moved from the internal hd to the external hd.
if i remember correctly the lightbox will follow a shortcut in the folder to other folders. that should help.
