Setting up Cintiq24hd's Radial menu to use Zbrush functions?
Hey Folks,
I just got a Cintiq 24hd and its great in Zbrush ( though its my first cintiq and its a learning curve like my first wacom) but I’m trying to set up the Radial Menu to acces things like Brush Alpha, Texture, Brushes, Strokes and failing.
Has anyone tried this and gotten it to work?
Is it perhaps a question of tracking down what the functions in Zbrush correspond to in terms of a comman in some hidden script file in amongst the zbrush settings folder? Setting up and Undo button is easy, I tell it I want to map a Keystroke, which in this case is CTRL+Z, then I name it undo.
I don’t know what the keystrokes are for those other commans and menus in Zbrush though. I’m not adept enough with zbrush to know the keyboard shortcuts, this is probably a newb question. I know there must be a simple txt file somewhere?
Thanks
k.
Will this help? ZBrush 4 Shortcuts
Works a treat , I’m very happy :slight_smile:
Sorry, I didn’t realize that there was a ZBrush 4R2 shortcut list. You can find it here.
