Setting smooth brush defaults
Does anyone else feel that the default settings of the smooth brush are massively overpowered? I know you can of course tweak the intensity etc but being set as default 100%, just can’t understand.
Anyway is there a way to set the smooth brush up so that whenever you apply it using the shift hotkey its at a lower intensity (10 or something) and is set at that setting by default? Currently each time I initialize it resets to the well high setting.
Try switching to the Smooth brush, setting the value you want, and then saving the brush.
If that doesn’t work, you could also create a macro that adjusts things how you want. Then you can put the button for that macro onto your Shelf where it’s convenient or you can assign a hotkey to it. So then you could just press a key when you launch ZBrush and everything will be how you want.
