Setting default document size.
I have looked in the online manual and explored all the menu options, but this is something that has been buggy me for weeks now.
How can I set the default document size in ZBrush?
Every time I start ZBrush I have to spend time resizing my document to get it to fill my monitor. The default is to small.
Thanks,
I haven’t managed to change the default size but if you resize your doc to your desired size and then save it in the startup docs folder you can easily load it when you open Zbrush.
seem to recall reading that its quite tricky to change the default load size but if anyone does know I would like to find out how too.
Thanks for the above tip, but this is becoming such a pain in the neck.
Anyone using a monitor at 1920x1200 has to always resize the document.
Can we get a response from PixelLogic on this issue, because I’ve searched the documentation and found nothing.
I found it!
http://www.zbrushcentral.com/zbc/showthread.php?t=65838&highlight=default+document+size
This was a hard thing to figure out. PL should add this to a FAQ list.
