Is there a way to set a point of view of my model? I mean, if i’m making a render and I have to close zbrush or I change the point of view and then I realize that I need other passes for my render how to return to that point of view?
There were plugins for this kind of thing but not sure if they survived closing and reopening.
I think the way to do it now is record a key frame (or more) that gives you different camera settings. Then make sure you save the project. I think that would work. but you’d have to try it (or have someone who knows what they’re doing confirm it)
You can save a camera position using the timeline; here is how you do it:
http://www.pixologic.com/docs/index.php/Timeline
if you save your tool as a project, the keyframes are stored as well; if you prefer to save as tool, you can export the timeline
hope this helps
Yep it is what I was searching for! Thank you!!
