When I do the select rect it selects not only front side but also the back side.would it be possible not to select the backside??
Just deselect the backside strg-shift-alt
Select Rect and Lassos will always cut through the entire mesh. If you want to target one specific area, you can either"
thanks for the reply
how can I convert to the mask from the black polypaint after the projection master??
Tool: Masking: Mask by Intensity will convert it into a mask
cool.thanks for reply
