seamless texture issue
hey people
i have a problem in 3.1 concerning seamless textures
i can produce them perfecty with help of the tilde key to pan the borders of a texture. i perfectly smooth out all seams with cloner brush. but when i grab doc in order to save/export the texture for later use on models, it is always grabbed/saved with a solid gray block that becomes visiblie when i tilde-pan agian on this grabbed texture oder when i throw it onto models with several texture repetitions later on.
thanx in advance
keiler
make your image 1 pixel bigger than you want.
that way when you export you can remove the extra black line.
hope that helps.
