Seam problem on Model
Hello,
I have been trying to paint over this seam with both ZAppLink and Photoshop and with Projection Master. I've also tried enabling TOOL>TEXTURE>COLORIZE>FIX SEAM on different border settings. Its not too obvious unless I zoom upclose, but I'm wondering if theres a way to make it truly seamless. I have posted some screenshots below. I am using ZBRush3.1 and 3dsMax9 and Photoshop CS2. Anyone have any ideas? [img]http://209.132.96.165/zbc/attachment.php?attachmentid=114080[/img] Cheers!
ps. anyone know why I can’t seem to get th eimages to show on the post? I attached the image and hi the place in post button. Strange…
I managed to get a better result gathering in my seam edges(Editing UVs) and Painting over with ZAppLink or Projection Master.
Please do post up if you have a better solution!
If you’re using FireFox, you’re going to need to type the ATT code into the text window. After you’ve uploaded the image, look below the text entry area. You’ll see a list of your images. Each image has a line of code that starts with ATT and ends with /ATT. Type that code into your text, and ZBC will show the image in your post when you submit it.
