Hi! ^_^! I have a problem in zbrush that I want to know if you could help me or know anything about it, I’m trying to edit my tool but it keep rotating whenever i want to sculpt or smooth, it won’t do any other thing than rotate, if you know anything about fixing please let me know I’d appreciate it so much!
check your keyboard, make sure some key isn’t active.
i open my on screen one and then x out of it, that resets the keyboard.
already did and is still not working :/, already tried even turning off the computer and it is the same.
[I’m on a macbook pro]
This can happen when the model is drawn onto the document with anything less than 100% z/rgb intensity. Try clearing the document, make sure your RGB and Z sliders are maxed out, and then redraw the tool.
Also make sure you have ZB4 R6 P2.
thank you very much!!
