Hi
i have two questions …
i use this script [IReset] , but when i run it they appear a message that say initialize and continue or skip etc…
i want to not see this message just doing the command , is there a way ? Also if i make script with button that use [IReset] command , when i press on the button and i then on initialize and continue the zbrush crash …
is there a way when i run big script and it start to do all the commands but if i press ESC button the script stop , is there a way to set something on the code of this script that if i press escape button the script will stop but do something other that i want
for example : if escape button is press do this /
Hope all this make sens
Thanks !
